y piece - any adjustments needed?
  • Thread starter Thread starter cbritton
cbritton
I'm going to have to fit a Y-piece soon and wondered if any adjustments are necessary ? Does it weaken the fueling or does the FI compensate ?
Cheers, Colin.
Speak to Gerry re this. His was incredibly weak on the dyno runs until a pwercommander fitted. You take your chance without one.
Get it Dyno'd!
I holed a piston and have put the cause down to my bike running dangerously lean in top gear between 60 - 80mph.
The lambda sensor and engine management aint good enough to sort out some bikes......some are ok but mine definitely wasn't.
Apparently GS's are setup lean from the factory and any tinkering can push em over the edge. It doesn't take much.
I'm now deciding to either sell my y-piece and can or save up for a chip or Techlusion. I don't believe there is a power commander for any BMW's??
The worst of it is I could have had a chip by now if I hadn't coughed up over £200 to replace the fried piston and cylinder!
