Yellow stain on front swingarm
pharme
Singapore
I spotted some yellow greenish stain on the front trailing swingarm and it's getting more and more serious. They are dried and hard to remove. Have seen this in a few 1150GS i've seen. What can I use to remove the stubborn stain, and what are they actually?
Stop pissing on your bike? (and I always thought the incontinent rode airheads?) :hide :D
Fuel leak stains.....
Lots have quick connectors with rubber O rings that can leak.
My GSA has a little bit. Sadly you can't get the stain off without a repaint.
As in piccy
Some have it under the throttle body where it gets under the lacquer.
If you have the QD connectors try replacing the O rings.
You will need 2 as in the piccy.
I bought 4, 2 spares that will go in the fuse box as emergency reserves..
As in piccy
Here's mine, not proud to share. Ill look into the QD connectors before it gets worse. Thanks Ash.
And you can see the paintwork on the valve cover, needs some work done too.
You can see the bottom of the QD connector in yer piccy......
I fecking hate those stains... :(
I am quite sure i didnt get the term right. What you call it from where you come from?
That's the Telelever.
The one the back wheel is bolted to is the Parlever.
You'll soon get the hang of it :D
Good see Ash (despite being daft) knew what you were referring to :thumb2
I caught the term from some ebay sales. It's a nice community here, always sth to learn. tx
