Deleted Account 180923001
Just copied the below in reference to someone having problems 'importing' files into the zumo. You can get the jist of the problem from my experience.
Just want to see if there's any thoughts about this .....cheers
g
..just editing this note: So to follow on from this, I'd forgotten you can transfer a route to the SD Card, but what's interesting and very strange is that a file transferred to the SD Card or the memory on the Zumo is immediately over-written the next time you transfer a route to the SD or zumo memory and any previous routes transferred to the SD or Zumo, but not 'imported' will not appear in the 'Import Data' list. ((Confusing)) (the SD card route is not over-written if the route has been transferred to the Zumo memory and vice-versa). I'm writing this down if for nothing else so that I don't forget but comments would be useful.
g
chubs...did you manage to resolve this problem. I've just dropped my routes into my 550 and, like you, all seemed good.....with the message along the lines of 'Data successfully imported'. However, when looking in 'routes' I noted there were 3 routes missing !!!! That made me remember that when I was 'importing' routes I noticed 3 files import within seconds (they obviousley didn't make it)....where as all the others took several minutes. I tried importing those 3 routes seperatly and all now OK. The file structure of the zumo is confusing to say the least. I thought the files 'imported' to the zumo came from the SD card but they dont (I took the SD card out and imported a route....I think it went into the GARMIN Drive - GARMIN Directory - GPX Directory and appearded as the TEMP.gpx file, which appears to be over-written everytime you upload a route from the PC to the Zumo....very confusing)
May be worth everyone who's got a zumo to check that the routes they have in 'routes' is the same as what was transferred from the PC to the Zumo.
gordo
