Zumo - Autocom volume
Ickaboo
Kent, England
Hi all
Can anyone tell me how to increase the volume from my Zumo through my Autocom.
Both bits of kit are new yesterday, working well, but low volume of GPS directions.
Sometimes there is a serious inbalance in my money / sense levels !
Hi all
Check the volume level of the Zumo, you can find it by hitting th spanner icon on the screen, the default should be 100% for navigation.
Have you increased the volume level on the autocom or on the Zumo itself?
Thunder
I have volume on Zumo set at 100% and the rider volume fully turned fully up on the Autocom ?
Thunder
Ok
Have you actually increased the actual volume of the Zumo as well as the relationship level between navigation and music ( the bit we just talked about).
Sorry if it seems a stupid question just starting with the basics :blast
No, I don't think so ?
When I alter the % setting on the music it has an actual effect, however when I alter the % level on the Directions it does not appear to have any effect (or should that affect ?). This is all on the Zumo.
Ok have you turned the actual voume of the zumo up at all?
Hit the bottom button when in map view then plus or minus which will show up on the volume level which will be on the screen.
As I said on Thursday Thunder your are the 'GURU'.
Just tried it in my van on the drive and hey presto !
Just wish I had asked you earlier then my wife would'nt have drowned out the GPS directions all afternoon with her inain babble !
I owe you a pint !
PS I agree with your comments re Diasabled Parking
