krisumo
I had some problems with the Zumo, which I posted a few weeks ago. I could hardly hear the nav instructions with all the volume controls at maximum. I first solved it using a Maplin £4.99 D-ring earpiece plugged into a 3.5mm stereo to mono adaptor (£1.29), which seemed pretty good.
I then got some tips about the Senheiser CX300, which I have'nt tried, and also the Scala Rider headset, which I have bought.
I wanted to hook up the phone with the Zumo, and the Scala Rider seems to have done the trick. The only trouble is that occasionally the Scala Rider disconnects itself, for no apparent reason and has to be re-enabled. Has anyone had the same experience, or know why that should happen? Could it be anything to do with the passwords, and can you change the passwords from the factory set ones? ie, does it get interference from other bluetooth devices enroute?
