Zumo voice
  • Thread starter Thread starter Row
Row
Hi can anyone tell me how to get voice commands from the Zumo 550, can i get them straight through my intercom or do i need extra kit ?
also is it possible to connect a bluetooth phone through the Zumo/intercom ?
Thanks in advance.
Thanks in advance.
Yes and yes.
Lets start with the intercom first. What do you have?
OK well for basic non phone connections you can use a 3.5mm 4 pole jack to 3,5mm 4 pole jack lead between the Zumo and the Autocom plugged into Aux 2 which will give you full voice prompts and music through your headset.
To connect your bluetooth phone through the Zumo you could use part number 1299 which connects via Aux 1 on the Autocom or the bluetooth adapter part number 1273 for the phone and an isolated lead to handle voice and music.
I'd recommend ringing the nice people at Autocom to talk through the pros and cons of each option. :thumb
Not sure about the Autocomm but I have my phone bluetoothed to my Zumo and the Zumo bluetoothed to a Scala Rider headset - works OK but only after I took the firmware down a level on the Zumo - the latest firmware kept disconneting and reconnecting the phone.
