Zumo volume & stuff
keithy
Lincolnshire
Have just replaced Navigator 1 with a Zumo, the Navigator has worked perfectly
with voice prompt volume perfectly loud enough to hear with ear plugs via Autocom.
Fitted Zumo with no alteration to rest of system result a great piece of kit except I can not hear it, yes I have loaded updates as suggested by Garmin and got all the volumes on max.
Have just spoken again to Garmin but have got a worrying response according to them no one else has complained about this? they have no knowledge of the effects of wind noise on hearing as leaving out earplugs was suggested (his mate rides and has no problem hearing it without plugs)
Other problems unit freezes completely with battery out to fix, great if on the M60 and can't remember the junction to get off or map screen goes pale yellow with no detail but voice prompts work if you can hear them.
Anyway it's going back to Garmin, I do feel :spitfire that the Zumo is great in every other respect but is unable to match the navigator on volume, not much point in having music and phone either if you can't hear them over 40 mph I might just as well have kept old slow one.
I know Autocom can boost their kit a bit and amplifiers can be bought but why should you need to on a machine which is sold as a motorcycle unit.:blast
Mines the same. Can hear pillion & B2B radios no problems, but anything above 40mph & nothing from the Zumo. Very poor compared to the 2610.
Baz
Find another member with a Zumo and do a temporary swap. Failing that, take a trip to Autocom and check against theirs.
Autocom will ensure that you leave happy!
Had problem with mine, but figured it was a problem with the autocom. Sent autocom back to them and it turned out I'd accidentally knocked one of the little switches inside the autocom unit whilst I fitted a longer pillion lead :blast.
Anyway, Doug at Autocom :bow :thumb2 reset the switch, plus tweaked the volume on the autocom (they can make some internal adjustments to the autocom to make the volume louder from the Zumo) - Now its much better.
Very very happy with the service from Autocom :bounce1:bounce1:bounce1
I have an old Pro 7 Autocom and had the same problem, however I had the leads plugged into the wrong bits on the Pro 7, now sorted and well loud...
