Zumo XT. Locked in a Touratech Zumo 660 ‐ Navigator V - Vl
Ash
Oh Yes....
Earth
Zumo XT.
Now fully mounted & locked in a Touratech Zumo 660 - BMW Navigator 5 / 6 locking mount.
Took me about an hour with a drill, file & pliers.
I knew I could do it..
:thumb
OK, I'll ask..... what did you have to modify?
Navigator 6 mount was east to get to fit the XT.
I drilled the mount holes in the metal mount to make the longer rather than round, so I could drop the XT plastic mount a tad.
Filed the top of the metal mount to allow the top to lock in place without touching the XT.
All very easy even with my u/s hands.
Now works a treat.
No doubt TT will bring out a locking XT mount ASAP.
Looks good and I am going to try to fit my new zumo xt to my touratech 660 mount. Can I ask was your tt mount the version 1 which hinged or the version 2 which raised up on a geared track?
And do you have any images of the mods you made?
Managed figure it out and good advice to elongate holes in mounting plate nearest sat nav to reposition the mount a tiny bit lower. I also removed the securing bolt and nut as this is not needed for the zumo xt. I mounted the zumo xt connector on some rubber spacers to give me the clearance to fit and remove the unit easily. I ground down a bit of the rear of the touratech mount where the release tab of the sat nav mount is to allow slightly better access.
Now wired & mounted on bike..
Navigator mount works Perfic on the XT..
:aidan
