How good and simple is that
The best one yet.![]()
Yes.. very good idea..
Keep it simple, removce end can , fit stubbie and bolt a couple of those plastic blocks that you use for flatpack furniture to the larger pannier. I have been using this set up on my R1150R for a few years now, never had a problem.
Is the same true for the R1100GS if trying an RT/RS exhaust?You really haven't given your idea much thought, have you..
You''ll still need a bracket to support the pannier.
So weigh up the cost of a stubby pipe, £20. Against the cost of an exhaust from an RT/RS, approx £250 for a used item, if you can find one.
And then you'll get to the major flaw in your suggestion - the balance box/silencer on an RT/RS only has one connection pipe as the RT/RS models have a two into one downpipe.
And don't think about just fitting RT/RS down pipes as they have three bolts at each cylinder head, the GS has two.
So you'll need to change the cylinder heads as well.
