ghiribizzo
And the screw inside the back of the airbox.
Why? He doesn't need to remove the airbox out of the subframe.
It would be easier with another pair of hands but you can simply lift it out of the way as you pull the box back.
Fit the clutch with the paint marks staggered 120Deg or as near as you can get it
http://www.ukgser.com/forums/showthread.php?153714-Clutch-replacement-YES-NO-tips-experiences
Just to say, this is a very useful and well timed thread
With this thread and other posts by Steptoe, I've got my 1100 to the 'removing the gearbox' stage which is going to happen today when my mate comes round with his extra pair of hands. Thus far it's gone pretty well to plan - I'm going to replace the clutch whilst its in bits (about 50k on the original). From peering through the starter hole, I think the clutch has escaped contamination from the gearbox input seal or pushrod seal (whichever is leaking - not sure yet) but it seems a false economy to not do it while its apart - I don't want to be doing this operation on a regular basis
Hope I can get it rebuilt in time for the Dragon Rally
One question regarding the crankshaft output seal - if it appears dry and leak free, would it be a good idea to replace it anyway, or just leave the original?...
My opinion, if it is Ok dont touch it, if they appear to be good leave them, a new one is not necescarily an improvement...
And my gearbox is off
The only tricky bit was the big earth lead which caught on the left hand battery box rubber mount as we pulled the box back (and broke the top stud off it) - I'll add one of those to the shopping list. Looks like that earth lead will be an issue when I refit the box - doesn't have enough length / flexibility to pass over the rubber mount. I'll have to work out a way round this...
Good call.
With the box and clutch off, peering through the holes in the flywheel, the rear face of the crankcase is bone dry. The seal is staying
The clutch however measures at 4.67mm (I believe the lower wear limit is 4.5), so I'm kind of pleased that it needs changing - it makes pulling the box more worth while.
Thanks again for this thread (and sorry for the hijack) - very useful.
Use a ratchet strap around the battery carrier and the handlebars and ratchet the battery carrier up a couple of inches.
When replacing the gearbox insert the clutch pushrod into the diphram spring and slide the gearbox along it (obviously while supporting the weight) into place.
Lever the earth strap with an old screwdriver over the battery box rubber mount as you slide the gearbox back. I do this single handed and it's fairly straightforward.
