You need to get the dealer to code that in. Last time I checked (about 3 months ago), they said it couldn't be done, but it appears that it can now.
The GS911 can do it already - at least on my old fashioned Hexhead it can! Can also change the temp reading between Farenheit and celcius.
I'm speaking cautiously here, as I haven't looked at the Hexcode website... but if the GS911 hasn't yet received maps for the new-generation LINBUS+CANBUS-equipped bikes, it should. Very soon.
Hexcode know that if they don't step up to the plate, it's only a matter of time before someone else does.
When using the nav V doesn't the RDC read in psi on the screen instead of bar.
Can than be changed to bar?
Sent from my C6903 using Tapatalk
Yes, if you switch the distance to mph, it will read in bar, and if you run in kph, it will read in psi.
Just tried it and it's the opposite way round.
Miles and psi
Kph and bar
If the option is there should this not be specified at the time of order so that it could be facilitated at the time of build?
It's a bit like no panniers available for the TE version even though the fixings are fitted
Can't see that that would be a practical option for BMW having individual order preferences for software settings. In my opinion its only software and it could easily be made programmable by owners however that would deny the dealers an opportunity to have time on the bike and an appropriate invoice generated.
Took mine to riders in Cardiff two weeks ago now have 24hr clock and psi readout, so it can be done (2013 LC)
As for paying the dealer to set the clock you've got to be pulling my leg.
