Deleted account 200123001
- Joined
- Mar 4, 2014
- Messages
- 2,372
- Reaction score
- 0
When I bought the bike supplied with it but not fitted was a K&N, decat, end can and a eprom chip.
Ran with the k&n and zorst mods for a while, just before a weekend trip to loch long I reset the tps to 369mv all was well, got great fuel consumption and bike ran well.
Shortly after I plucked up the courage and fitted the eprom chip.
Bike didnt run too well and was back firing on over-run quite alot,
backed of the tps back to 361 in case it was over rich...not really any better.
With the chip in the bike developed a strange noise on WOT in 6th it sound like small stones hitting the sump guard (theres none in there by the way).
So have removed the chip and (for no reason other than noise) stuck the standard end can back on and reset the TPS to 371.
With the chip out its still back firing on over-run doesnt feel quite and right and is still making the same metallic noise as when the chip was in.
Incidentally 2-2.5 glitch is much better now.
The bike is very "fumey" on start up that first puff of smoke is noticable and strong.
1). If the chip was badly programmed could it have damaged the engine?
2). The plugs seem a little heavily contaminated for my liking especially the off side one, which incidentally was missing the rubber cap off the throttle body nozzles (overly lean mixture causing pinking under heavy load).
3). Does the ECU over right the maps of a new chip when the new chip is installed if so can the "maps be purged" and reloaded when the standard chip is installed?
- n/s cyl
- o/s cyl
- the offending chip
- n/s cyl
- o/s cyl
