Doeas seat and tank fit from 1150 to 1100GS?
Antti
Finland
It should be a astraight swap, shoudn`t it?
I`d recover my plastic, bubled tank with steel one.
And use old pump+filter assy and cap.
Yes.Should be no problem.
I have fitted an 1100 metal tank to my 1150 using the 1150 pump and filler cap.
2 rubber strips at the back of the beak will be different - you'll need the metal tank type.
Yep, I did just that when my plastic tank bubbled.
As others have said, the rubber beak trim pieces are different for the metal tanks but they're still available new. You'll also need some m4 nuts for the fuel pump access plate as the steel tanks have studs rather than the tappings that the plastics have.
Hey im putting a 1150 tank on my 1100GS do you have an idea where i could get the differant rubber strips from? Cheers
Depends on if you currently have a plastic tank or steel one. Steel tank ones are srill available from bmw
Sent from my SM-N975F using Tapatalk
Thanks Feisty i managed to get a set i needed the stell tank rubbers.
