GSA lower screen mount lugs
MattW
Cheshire
I dropped my bike while stationary at a fuel station a few weeks ago :blast
As I managed to 'lower it' down rather than it falling with full force, I thought I'd got away with just a scuffed engine bar and cylinder cover and a slight scuff to the side of the screen (it fell against a kerb and the screen took some of the force). However, I noticed that the screen seemed slightly twisted afterwards.
I've just got round to taking the screen off to see about realigning it only to find that one of the lower screen mount lugs has snapped leaving its 'pin' inside the bottom screen bracket. The upper mount bar has also slightly twisted out of shape but that's easily sorted with a bit of brute force.
Does anyone know if the lower mounting lugs are available as a separate part?
I'm now off to try and get the snapped off pin out of the bracket, which will probably be fun as its snapped off flush...
Pic of the offending item below, together with its I damaged friend.
You can buy metal replacements Do a search it was mentioned a week ago
Ok, just ordered a replacement from Motorworks. I assume (hope) that these are metal as fitted to later bikes like mine - we'll see...
Got the old pin out by drilling through the blind hole on the other side and pushing the snapped off pin out.
I'm going to try and make a temporary repair by drilling and tapping the old lug and threading a bolt into it to act as a new pin.
Done.
Perhaps I should have saved my £12 :rolleyes:
You could drill through the screen front bracket and use a 100mm (approx) threaded bar or stud threaded at each end. 75mm lengths of aluminium angle (15 x 15mm or wider) bolted either side will make yourself some Tobinators.
All usual caveats about at your own risk etc and you might need a wider angle to do the job, filed down as necessary for a neater look.
All done and back together now. When it arrives, I'll stick the new one from motorworks in the tool roll as a spare.
I've often wondered what tobinators actually look like (never having used or even seen them).
