Nippy Normans supply Touratech, Wunderlich and many other makes of accessories.
Page 1 of 3 123 LastLast
Results 1 to 16 of 34
Thread: exhaust flapper
  1. #1
    Join Date
    Nov 2011
    co durham,england
    Posts
    1,325
    exhaust flapper
    hi folks is there anyone on here making these things to eliminate the exhaust flapper
    http://www.ebay.co.uk/itm/BMW-R-Nine...3D161953804449
  2. #2
    Senior Member Click here to find out how to Subscribe
    Join Date
    Sep 2012
    Torbay, England
    Posts
    28,048
    Try any exhaust specialist that offers stainless pipes.
    Alternatively, fit any exhaust system from the 1200 Mk1 or Mk2 that did not have the flap valve. They all have the same mounts and straight swap.
  3. #3
    Join Date
    Nov 2011
    co durham,england
    Posts
    1,325
    i know mate,i just someone on here may have made a few of them and still have one lying around
  4. #4
    Senior Member
    Join Date
    Jul 2010
    Cirencester,Cotswolds
    Posts
    273
    yeah i've a piece of Stainless Pipe from a fellow Tosser on here, works a treat, removes the sticky Flap.
    try a search as it was two years ago, just a simple tube unlike your e-bay item.
  5. #5
    Senior Member
    Join Date
    Feb 2010
    Sunny Warrington
    Posts
    314
    http://www.nippynormans.com/products...-wun-20200-000
    try this if you cant get one off here
    Andy
  6. #6
    Join Date
    Nov 2011
    co durham,england
    Posts
    1,325
    Quote Originally Posted by APW View Post
    Andy
    thanks i did not know nippy sold them
  7. #7
    Join Date
    Mar 2015
    Southampton
    Posts
    1,341
    Blog Entries
    7
    The flap valve is 63mm outside diameter and 67mm long with a wall thickness of 2mm. Go to a local metal supermarket and get some stainless pipe cut.
  8. #8
    Join Date
    Nov 2011
    co durham,england
    Posts
    1,325
    Quote Originally Posted by Bungy View Post
    thanks mate ,brilliant
  9. #9
    Join Date
    Mar 2015
    Southampton
    Posts
    1,341
    Blog Entries
    7
    I took mine apart today for no other reason than interest. It wasn't fully open but free to move. I took measurements and removed the 2 cables completely. I'm guessing that the servo box needs to stay or it'll throw up a fault code through non communication. I replaced it until I can get a stub pipe to remove it altogether.
  10. #10
    Join Date
    Nov 2011
    co durham,england
    Posts
    1,325
    to honest when i take the flappy valve out,i was also going to take the servo unit cables the lot out,and just cable tie the multi plug out the way somewhere
  11. #11
    Join Date
    Mar 2015
    Southampton
    Posts
    1,341
    Blog Entries
    7
    Quote Originally Posted by fizzer View Post
    I've done some more reading and that seems to be the way ahead. I'll remove all of mine and see how I get on.
  12. #12
    Join Date
    Nov 2011
    co durham,england
    Posts
    1,325
    yeh the way i read it is ,if a gs911 is plugged in it will show up a fault on the flappy valve ,as its not in place ,but it dont show any warning lights on the dash
  13. #13
    Join Date
    Oct 2012
    In a Remote area apparently.
    Posts
    7,491
    Ł30 fron NN ? piss take of the highest order. Get a piece of pipe from your local stainless supplier.
  14. #14
    Join Date
    May 2014
    Downpatrick, N Ireland
    Posts
    784
    Just fitted one from Nippy Normans this evening.
    Yes, seems a bit pricy for what it is, but can anyone really say that any of the after market exhausts that many of us fit are worth up to Ł5-600?
    The NN piece is fine and the edges nicely finished and was a perfect fit. It arrived in the post today and it's fitted. Good job.
    If you can be arsed taking the time to go to an exhaust supplier, explain what you want, faf about until they cut it and then travel home again to save a few quid, then go for it.
    I just removed the exhaust and flapper valve, along with the control unit. Removed the cables from the control unit and covered the holes where the cables were with pvc tape. Replaced the unit and plugged it in again so no fault codes show up.
    While I had it all off, I gave the clamps and pipe ends a good clean with emery paper and a rotary wire brush.
    Used a bit of copper grease when putting it together so it comes apart a bit easier next time.
    Looks a neat job and there's a nice bark out of the standard silencer now. Fronts have been de catted btw.
    Recommended mod for the TC even though the flappy valve on mine was still working.
  15. #15
    Join Date
    Mar 2015
    Southampton
    Posts
    1,341
    Blog Entries
    7
    I got a few cut today and fitted mine removing everything else. I'll stick all the bits in a box and put it on a shelf in the garage in case I decide to reinstate it at some point in the future.
  16. #16
    Join Date
    Jan 2002
    West Dorset on the TET/GWT
    Posts
    11,685
    What's the benefit in doing this mod...
    Sell my bike?
    I would rather stick wasps up my arse !
Posting Permissions
  • You may not post replies
  • You may not edit your posts
UKGSer is....
"A vent, a source of info, a source of bullshit, a source of humour and in the coming months, possibly a source of sanity." Big Lad March 2020
"I have always known this community is full good people even if most of you cover it up with piss n vinegar" Chad 2018
"Its about being a grown up hooligan - and if that means a dark visor, remus open pipe and a bit of speeding out of town then all well and good" Kaister 2005
