alp
Just thought I'd let you know where to get cheap frame plugs for the 7 places where simple round plugs will fit to tidy up the side view of the GS.
The full kits available from the usual sources cost an arm and leg (but do include the 2 awkward tube ends i.e. swing arm pivot and the one just below the seat cut at an angle).
Anyway, the source for the simple round plugs is 'ktsparts2015' in Durham, I found them on ebay and they only cost pennies.
The items are 221817431048, Round black End Caps Insert Plugs, Black. You will need 3 off 25mm outside dia and 4 off 38mm outside dia. I had to lightly dress the part of the 38mm plugs which fits into the tube to avoid too tight a fit.
Hope this helps.
Hope this helps.
