ok, home now and getting in to this
Checking the easy things first
It seems that I have a different problem now that it has been sat for 10 days.
the clock was displaying just fine.
I put the key in, turn the key to the ignition and the clock goes out after a moment and the RPM Tacho flicks up to about 2000rpm and then back to zero., no headlight and no start or anything.
I am going to work through the list I developed and report below.
Fuses - all fuses are fine
When I turn the ignition on, no lights come on, the clock display goes blank
battery is 25months old
battery voltage is 12.62 volts
(the above three items could indicate a duff battery - but I would expect the dash panel to remain unless the battery was really dead - but it has 12.62volts)
engine rotates by hand fine (there fore starter motor unlikely to be locked in to flywheel)
I removed the HES system (lots of black dust in there - alternator belt could have been a bit tighter I think)
and checked that (dodgy HES seems to be indicated by weird indications on the engine RPM Tacho)
All the connections seem fine, am getting continuity through the pins.
I have bypassed the side stand switch following the 1150GS section of this document
http://advwisdom.hogranch.com/Wisdom/SSIBD.pdf
I have just tried a jump start off the Land Rover (no bashing please) and same result as above (no start, no nothing)
The Land Rover would have given it plenty of oompph, but no change.
I am thinking that the 'ignition off' circuit is fine, enough to display the clock.
but when I go to the ignition on position on the key, nothing. This indicates to me that the electrical path the main system is not working.
Relay 4 - Load Relief was one of the relays that was chattering away, possible THE one but I wasn't able to identify it for sure (see more below - have id'd it)
yep, checked that and with a good connection (two bits of wire to the battery) latches / un-latches and no chattering. However, if I didn't get a good connection, it did chatter.
Relay 6 - Fuel Pump - as per relay 4
Relay 7 - Motronic - as per relay 4
Relay 3 - Starter Motor - as per relay 4
(thank you for the diagram of the relays and fuses
http://www.ukgser.com/forums/showthread.php/354312-1100-1150-fuse-and-relay-What-and-where! )
So now I am thinking that there is a problem with a switched circuit - starting at the ignition barrel because in X position (ignition off) it is ok, but when in Y position, nothing.
Now I think of it, the key switch had been stiff sometimes but of course, I didn't think anything of it.
If there is a problem there, that could be the reason the jump start didn't work, because other systems were not being energized.
I then looked at removing the ignition barrel, but that looks difficult. There are only 5 wires coming from it and so I am going access the connector block and check the wire continuity there. ewww, each of those pins in the connector block is pretty dirty and ver-de-gris. needs a clean first.
I then thought about just making a circuit, the red and green wires (from here
http://www.ukgser.com/forums/showthread.php/313367-Colour-R1150GS-Wiring-Diagram)
and got the sound of some relay(s) latching but still no start and the RPM Tacho deflecting for a moment.
OK, well, maybe that rules out the ignition barrel. (cleaned the pins anyway)
I then turned the ignition off and pulled the relays out completely in this order
removed relay 4, ignition on, hear a latch, clock goes off and tacho needle deflects momentarily
removed relay 5, ignition on, hear a latch, clock goes off and tacho needle deflects momentarily
removed relay 6, ignition on, hear a latch, clock goes off and tacho needle deflects momentarily
removed relay 7, ignition on, DO NOT hear a latch, clock remains ON, tacho needle does not move
Relay 7 is for the motronic system.
hmmmI then re-install the relays in this order
Relay 5 (horn) - no change, nothing
Relay 6 (fuel pump) - that time I pressed the start button and the relay engerised (fuel tank removed so dont know if the fuel pump primed (and not able to id the wires for the pump)
Relay 4 (load relief) - relay buzzed, RPM tacho climbed to 6500rpm, clock stayed on. I pressed the start button - nothing
I then re-inserted relay 7 (motronic) and got the same original results.
That tells me that the load relief system has / is causing the problem
mmm, so next think.....
keeping it in the theme of simple stuff,
a search on ADV suggest to swap the horn and load releif relay. Even though I function tested them, wont hurt - as expected - no change
Fuse #3 got a few mentions, re-racked that a few times - no change
I found this on ADV:-
There are a few tricks you can do in the fuse box to check whether the ignition switch is faulty or not.
Remove fuse 1 and 3.
If you jump from the rear position of fuse 3 to the front position of fuse 1 then the battery and oil lights should illuminate.
If you jump from the rear position of fuse 3 to the rear position of fuse 1 then the lights and Abs should power up.
Assuming both these work then I would suspect your ignition switch
Nope - no change when trying that
(this thread for reference
http://advrider.com/index.php?threads/gs1150-adventure-dead-electrics.1114648/#post-28348614)
reading all of this thread, i am thinking a problem with the ignition wiring system - as suggested by the knowledgeable steptoe.
mmm, not to trace that wiring harness......
so I went out, ignition on, Relay 4 (load relief) buzzing away whilst I wiggled all the wires around the orange connector from the key barrel.
Relay 4 started buzzing higher and higher and the RPM Tacho went up to 6000rpm.
I pressed the starter button and the buzzing changed frequency ever-so-slightly
For some time now I have not had the panel over the starter motor installed - just never put it back on.
For some reason, i thought to remove the single black wire from the starter motor solonoid.
NOW, when ignition on, I get a single click of a relay latching, the clock stays on AND I get gear position indicator on and the RPM Tacho stays at zero.
I have removed the starter motor and dissconnected the wiring
Now time for dinner
New suspect item - starter motor assembly - or the wire that connects to (at the moment buggered if I can remember what that wire does)
i just pulled the starter motor apart and the bendix gear / throw out shaft thing - gummed up SO stiff and tight.
Bit of light oil to work it, then clean the shaft up and now it moves just fine
I have posted in the starter motor thread (the sticky at the top) about cleaning it
I am not sure if this is the problem though - the single wire is connected to the solonoid part and when I disconnected the wire, the problem changed
I want to clean the solonoid some how.
Looking at that now
In the mean while I have reassembled the starter assembly and re-installed
Well, I cleaned all that at least
No change, still a problem
I dont know at the moment
there seems to be a link in the starter system / load relief relay / single wire on starter solonoid
I don't know where to go from here, suggestions welcome
I feel pretty sure that I can rule out the battery now
thanks
