Nextbase Ride Dashcam.
Gargy
Gloucester United Kingdom
How I permanently fitted the above camera.
Firstly I fabricated a stainless steel bracket fixed the the throttle side indicator mount point. I had to buy a 1/4" UNC st/st bolt to fix the camera to the bracket.
[/URL][/IMG]
Camera mounted.
[/URL][/IMG]
Then to find a switched supply, which was under the riders seat. The one with the red wires.
[/URL][/IMG]
Remove the 7.5amp fuse, and replace with a piggy back fuse holder.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Then tuck all the wiring away. I put the 12v to 5v converter box which comes with the kit just behind the tank, and run the wiring under the top plastic tank cover. The top tank cover was the only panel I had to remove, and this was an easy install.
Piggy back fuse holder........... http://www.ebay.co.uk/itm/1-X-Mini-...369380?hash=item3ad5480264:g:oHQAAOSwOVpXfScg
[/URL][/IMG]
It's not going to show anyone rear ending me either................. best I get another three camera's to get all angles covered.
It doesn't matter where I put it. It's always going to be a compromise using one camera.
