Hi, new to the site and haven't been able to find any answers to my problem!
I have had an issue with the KOMBI unit which I cannot resolve. It basically started with the clock on the display only operating when the ignition was on. It would stop (but keep the current time at shutdown) and then start once the ignition was back on. Now when I turn the ignition the instruments fail to test and work, I can start the bike, and all other sundry electrics work (horn, indicators etc) After riding for 5-10 minutes the instruments test and work normally. I have changed the battery and cleaned connectors, I have removed the KOMBI unit and checked the connections and for any damage/cracks/water ingress. The problem persists. I have a GS-911 diagnostic tool and attached is a print out of the errors which indicate present. The same errors indicate not present after the instruments start to work.
BMS-KP 10218 CAN-bus timeout.No communication with KOMBI
ZFE 41756 CAN-bus timeout.No communication with KOMBI
ABS8M 59698 CAN-bus timeout.No communication with KOMBI
Here's hoping
Here's hoping
