Hi from Hampshire UK .
A couple of questions. Wondered if any inmates could shed any light on the history of my bike, NJ51 WJM.
I think it spent its life in the North ?
I bought it a couple of weeks ago 78K miles. It had a very noisey starter but it started the bike when went to view it - from cold. I went to collect a week later and it started again from cold. I have started it once at home, then left it a week and then tried to start it and at that time the starter made a horrid grinding noise, slow turnover and the bike wouldn't start.
I have removed the starter it has no makers name or sign on it and seems to be lacking the locating pin. (could this be a cheap starter?).
The starter has damage to the bendix and there is resulting damage to the flywheel.
This damage to the flywheel teeth is in two patches on the flywheel and covers about 20 teeth. The rest of the flywheel is ok !!
There is damage to the outboard starter mounting bolt and some one has drilled right the way through the casing and mounted it using a bolt. is this acceptable practice ? or could it be causing some misalignment problems? i have attached some photos below. I have ordered a 2nd hand valeo starter to see if this is any better quality. And james sherlock has a flywheel listed on fleabay, I think I will buy this also.
Any thoughts on best way forward? thanks Mike
