BaseCamp: Change end point?
Pauleduc
Fenelon Falls, ON
I created a rather detailed route (that I prefer not to recreate!) and wish to change the end point. In basecamp, it appears ok.. that is, I can drag the end point to another spot on the map. However, when I double click on the route, the detail shows that the end point is the same! Also, if I download the changed route to my Zumo, the route still shows the old end point, not the new one.
Is it possible to modify the end point on a route?
Just drop another end point in as a way point, add it to the route and then delete the original end point
Simples although you should just be able to drag the original end point to the new and re calculate
Thanks.. I think it is working as I wanted.. the problem was that the end point had the same name.. even though I moved it to another restaurant, it kept the name of the original restaurant, so it was misleading. Thanks!
