Finally got round to fitting....
loadmaster
STOCKPORT
LED spotlights. Lights are triggered by the AUX feed to a 30Amp relay and can be switched on/off by a 2 way waterproof handlebar switch. Really pleased with how they look and output. Mounting bracket was purchased from Rugged Roads.
Its recommended that on the F650 the spotlights should go under the bracket & the F800 on top. If there's any problems I'll try them in the lower position.
Rugged Roads bar is a decent bit of kit. The problem is that they only fit a pre-2013 model, as i found out. Still, it looks good sitting on garage shelf
