Clutch lever
(RIP) DanaG
Member
Reading, UK
I snapped the clutch lever off the F750GS. I order a replacement at Motoworks. Any other places you could recommend? I get the impression this is not going to the last time this will happen.
My impression is that the F750GS low chassis is jut a bit taller than the 700GS. I put my foot down and there was no ground due to drop in road.
You may be right. Ignoring any difference in seat profile the lowered F750GS with low seat is 770mm, and the corresponding F700GS seat height is 765mm - not much but together with a slightly wider shape on the F750 it may make all the difference. Any reason not to replace with OEM levers? Do you have handguards? If not, it may be worth fitting them.
