Hi guys my wife's radiator fan has stopped working I have checked the fan motor by connecting it to a battery and that is fine. Other than the thermostat in the rad can it be anything else?
Cheers.
Cheers.
Bugger;Hi bud no fuses on this model it's a canbus network system.
Silver one, will likely be oil switch, they usually earth via engine, and gold for water temp.Found tow sensors on the back of the block is one oil and the other water? One is gold in colour with two wires going to it the other is silver with one wire
You've bypassed the sensor, and still nothing. As it understand with canbus, fan gets triggered by signal from sensor. If I wrong, hopefully someone will correct my error.Well the plot thickens, replaced the fan and still nothing I crossed the terminals to the temp,sensor and still nothing no power going to the fan connection! Any ideas folks?
Maybe someone near to you will help out, there are quite a few kind and helpful souls here.It's sure getting a little frustrating hopefully someone can shed some light on the situation.
I don't have a Gs911 unfortionatly
Hi ash, I have bench tested the fan and it works fine on the bench but just in case I have ordered a second hand fan to,see if I can get it working again. Very frustrating.
