Need a mechanic in S Wales that knows Servo brakes
luckylucian
South Wales
2004 R1200GS, servo on rear brake stopped working :blast, can anyone suggest a good mechanic in South Wales to take it to pls?
Theres a guy down west who knows his way around the 1200, cant remember his name sorry,but I can tell you most will say remove the ABS and servos for reliable brake.
I don't think it can be done on the 2004 to 2007 without an error code but am open to be corrected, would save me a fortune
Yes it can !!
You repipe the brake pipes as a non abs bike
Remove all the rest of the ABS unit "BUT" separate the Electronics box from the unit "CAREFULLY!!!"and seal it up and refit it back to the loom and secure it back on the bike
Remove the dash
Split it and cover the two warning lamp holes or paint the LEDs
Put it all back together Bleed the brakes
AND Robert would be your fathers brother!!
No Extra bits needed Speedo and lights and Brake lamps work as prior to the removal
Yes and no ;)
Yes - You can servoectomise as DrFarkoff details, and the brakes work with nos problems
No - Error codes are produced due to the now removed servo not recieving expected values.
However the good news is - the codes are non visible & will only show on conection of a dedicated code reader.
THe BF light on the Kombi will stay iluminated, but can be addressed - do a search of the forum
Ive done it on my 05,
I bought the bmw fittings to keep it looking stock, split the clocks and painted over the leds on the dash.
Its not hard, but the fella I mentioned down west can do it as ive spoken to him at the cafe a few times.
Is that Trevor?
When did he do the work on your bike? Many years ago Phil did some good work on my 911.
There was a 911 on his ramp for several years looked almost beyond recovery, was that yours?
Phil is a good guy, been through a lot of aggro over the last few years which he did not deserve
Thanks, will give him a call. Mine was a 1976 2.4s....wish i had kept it
