1974 Airhead on Sorn last year, online today--------comes up with historic status and no mot required,all done automatically,can't fault that!!
got a 1976 r100rt woud that be the same you think ??
I have a 1960 Lambretta, taxed ‘Historic’ and up to very recently I’ve had it MOTed every year. It now needs an MOT but the tax is current. How can I change it to MOT exempt? The only procedure I can find is when retaxing at a Post Office you can declare it as exempt. But in the meantime is there anything I can do? It’s used so rarely I can’t be bothered to have it tested if I don’t need to. I do have other vehicles that I use more often and I do have these tested for my own peace of mind as a ‘second opinion’.
Everything I can find only applies to when you retax it. I has 11 months still to go but the MOT has now run out. Tax and MOT were out of sync.do it online it should go through automatic
What does ‘substantially changed’ mean?
A vehicle where the technical characteristics
of the main components have changed in the
last 30 years. These components (other than for
motorcycles) are the chassis or monocoque
bodyshell (including any sub-frames), engine
and axle and running gear (alteration of the
type and/or method of suspension or steering).
