Hi folks, immediate apologies if this has been covered elsewhere but I can't find anything specific. I have a 1989 R80GS but this query is probably pertinent to all airheads. I'm fitting a bunch of electrical stuff - lights so I can actually see where I'm going, satnav, heated grips. Experience tells me that to wire these straight to the battery will eventually lead to a bump start in some muddy field far from home because you forgot to switch something off. Conventional wisdom says use relays and an ignition live trigger from, say, the rear light live, which I've done. But I was looking under my seat the other day and thinking 'this doesn't look very good and even with the relays it must be quite a draw on this wee thin back light wire'. Anyone come up with a better solution? Cheers, Poon.
