NicD
https://ibb.co/r0Zj2mr
Battery with tabs spot welded on. Also a Varta as I didn't want a cheap one as per most ebay listings for 2032s with tabs
For removal of battery, do not follow N van den Berg's doc. Break spot welds on existing positive first, remove resin from behind tab, then bend tab up. Remove resin from around battery after doing this - it ensures battery held firmly in place while spot welds broken. Then lever battery up by positive tab as negative tab is at 180 degrees to positive. Lift battery as little as possible to put as little pressure as possible on negative tab. Break spot welds. There are two spot welds top and bottom.
For soldering new batt, I found easiest with tabs on new battery pointing away from sensor tab, and then folded back on itself.
