Damn and blast, more unnecessary expense.
Rugged Path
The Honourable.
Wybunbury, Cheshire East, England, EU
A bit chilly today and windy but, usually doesn’t put me off going for a ride. So a ride it was.
Parking up at a cafe, I opened the alu OEM top box to put gloves in and take my Thermos mug when wind caught the lid and broke both the hinges .
Noticed on Motorworks they are £38 each .
Time for a change to stainless hinges as the OEM have alway been the weak spot especially without the safety cable ( which was half installed on one side). My fault .
Are there hinges available that fit the original holes out there?
First will try the diy shops.
Sent from Steve's fancy iPad using Tapatalk
Looked at those links,
First does not open and second under maintenance.
On Amazon I see an E6-10-420 / 430-50 @ £16.34
These are for the constant torque position control hinges.
If the size is 430, I will order a few extras as well.
Found it.
Will measure broken one to gauge correct dimensions before ordering.
The metal hinges preferred over existing plastic ones.
Just contacted rs-online to enquire the difference between E6-10-430-50 Symmetric and E6-10-440R-50 Asymmetric.
Large E6 hinge is the correct size and it is just the above parameters I am not sure about.
Hole distances are 34mm.
Perfecto fitted and no way a hurricane will push it back.
We stock those hinges at work. We build vehicle bodies.
I could do you them mucho cheaper.
Those are the standard plastic hinges from SouthCo as OEM fitted.
What I bought are aluminium with friction torque control hinges.
Sent from my MI 9 using Tapatalk
The Southco Hinges I used are not plastic like the OEM ones , they are aluminium powder coated black
