ABS Fiesta pump replacement
Blood1
Rotherfield East Sussex
I run a R1200RTP. Brake failure light is on and I've had the system check at a dealer Coopers in Tunbridge Wells Kent. So the unit is faulty and needs attention.
I have read that you can replace the unit with a Ford Fiesta unit. I have now aquired a pump I used the number given off this website. However the unit has two extra pipe holes obvs for 4 wheels. Can you advise which holes I should blank off and the ones I should use ? Thanks
ABS Pump repair
I have succesfully replaced the ABS motor from a Ford Fiesta and fitted to my R1200RTP. You cant use the Pump itself as to many outlets.
i think you need to swop the pump over on the 2 units. The pump is the big black cylinder. there are some youtube videos showing you have to do this and how to check the pump. Word of warning, dont take the pump apart like some videos as its a pain to get it back together correctly.
