Results 1 to 14 of 14
Thread: What are these for?
  1. #1
    Join Date
    Oct 2016
    France
    Posts
    28
    What are these for?
    Found these cut wires under the seat, any ideas guy's.
    Attached Images Attached Images
  2. #2
    Join Date
    Mar 2009
    Worcs. England
    Posts
    3,336
    Quote Originally Posted by Wardy View Post
    Can't see, some numpty's got their finger in the way!
  3. #3
    Join Date
    Jan 2002
    North Yorkshire
    Posts
    33,998
    Rear number plate light, on oem plastic rear fender ..............maybe
    JohnnyBoxer
    So many roads...........So little time......
  4. #4
    Join Date
    May 2004
    Wirral
    Posts
    16,546
    Can't see, but sidestand cut out bypassed, maybe?
    Huic ipso mundo ego odi
  5. #5
    Join Date
    Oct 2016
    France
    Posts
    28
    Yep...sure could be number plate light, it runs separate to brake light etc, I'll check that thanks. On another note, trying to get sub frame bolts out, one top, one bottom corroded in. Been soaking in wd three days, tapped them, small impact gun, still not turning. Any ideas ?
  6. #6
    Join Date
    May 2004
    Wirral
    Posts
    16,546
    Get some heat on them.
    Sometimes it's worth trying to tighten bolts a little bit then undoing them.
  7. #7
    Join Date
    Oct 2011
    Hertfordshire
    Posts
    1,735
    Treat yourself to some Loctite freeze and release. If that doesn't free it nothing will.
    Anyone riding slower than you is an idiot, and anyone riding faster than you is a maniac
  8. #8
    Join Date
    Oct 2016
    France
    Posts
    28
    Cheers guys, heat out of question, don't know about loctite freeze, see if I can find some.
  9. #9
    Join Date
    Oct 2014
    Hexham , Northumberland
    Posts
    550
    Looks like it could be the unused carbon canister connector (with the plug cut off) that is used only on US spec bikes
  10. #10
    Join Date
    Oct 2016
    France
    Posts
    28
    Thanks John.
  11. #11
    Join Date
    Jun 2002
    Reading
    Posts
    15,466
    Quote Originally Posted by Tarka View Post
    A trick that's done well for me, but "little" is important.
    Never trust a Tory Toff
  12. #12
    Quote Originally Posted by nicholsonj2252 View Post
    That's my thoughts as well. Handy if you need a live feed switched with the ignition!
  13. #13
    Join Date
    Sep 2012
    Berkshire
    Posts
    1,405
    Are they live? Lick them, lick them...you know you want too
  14. #14
    Join Date
    Oct 2016
    France
    Posts
    28
    Click here to find out how to remove these ads
    After a week of soaking in we, top one turned out, no such luck on bottom, so was easy drill the head off, turned out bolt stem, simples.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
"Its about being a grown up hooligan - and if that means a dark visor, remus open pipe and a bit of speeding out of town then all well and good" Kaister 2005
"I have always known this community is full good people even if most of you cover it up with piss n vinegar" Chad 2018
