Punctures...
Can't see Ultraseal working very well in a tube especially if you are running lower pressures for off-roading. Have you fitted off-road heavy duty tubes?
According to their blurb it will work with tubeless but won't be so efficient. I've decided against using heavy duty tubes as they mostly have a low speed rating and I'll still have some long road days as well, instead I'm going to use pure rubber tubes made by Motoz from Adventure Spec, bit more expensive but they do get brilliant reviews for durability.
