Can you really not be arsed to look in your manual?
Somebody else has to, to answer your question....
Looked but Doesnt say, only engine oil............
Thank you, that will do for me.
And how do you check the wheel balance?
I used to do it on my hex heads and used to have to split/tilt it to drain it.
If anyone has any schematics of the LC FD relevant to oil changing I’d be grateful.
Final Drive Service Specifics for 05-09 RT/GS
A reminder note about unscheduled/early final drive service. (Normal BMW recommendation is 12000mi)
Hope this helps with your service efforts for those folks that may be unnecessarily changing the FD fluid with every engine oil change at the 6000mi to save a bearing that's not even in the FD oil that is being changed.
I wasn't actually changing the oil every service to save a bearing
I decided to do it, mainly because.....
a) I want to drop the final drive to see what the heck is going on with my shaft splines, detailed rubber gator inspection, final drive splines and re-grease it all if necessary. To do that I need to evacuate the oil so it doesn't spill out the open speed sensor hole.
b) May as well clean the magnet on the drain plug and refill with new FD oil, only because it's fast and cheap to do so.
The whole job probably only takes an hour and at least you know the shaft connection is water tight and greased up again
Going to look at my final drive soon. What grease are you guys using on the sealing surfaces of the final drive rubber boot please?
This stuff as it's used by BMW and thicker/stickier than any other grease I've seen.
https://www.ebay.co.uk/itm/GENUINE-...a-2706-4d42-843a-4c2cd173c93a&redirect=mobile
Got the diff oil coming today so going to give it a full service the weekend.
