How does the auto blipper really work, the engine must be disconnected from gear box in order for the revs to be instantly raised - I assume that the slipper clutch is just forced to slip.??? It just doesn’t feel right on my bike other than occasionally when slowing rapidly under brakes and down changing, but it all seems a bit crude so I don’t bother using it and continue to manually blip using the clutch.
From what I’ve read as many people are finding the trigger to be mis aligned, occasionally by a fair bit. That may compound the timing issue if it’s all out of alignment.
No the back torque limiter isn't affected. It happens really quickly.
As the engine cuts ignition, it unloads the gearbox momentarily to allow you to shift gear. this 'moment' is called the kill time. Kill time is pre-programmed to be a certain value (like 60 milliseconds) which is enough time to complete the gear change and then reload the gearbox as ignition restarts.
It's very fast.
Have you altered your trigger position from factory settings?
Nope, I just found a post by a guy in the US who documented all of the wet heads he timed. Out of 6, 4 were out on both sides and 1 on one side, the other was fine. 4 of them also had mis aligned triggers, and not always the ones with cam timing out.
No mention by them of shift assist related differences but smoother idle and less vibes etc. But it’s pos they just did not make a connection re shift assist and timing.
When shifting you slide the dogs back and forth between the different gears, and one gear has to be released prior to engaging the next one. The quickshift use this gap to either drop rpm (by chopping ignition) for upshifts or blip rpm (increase) for downshift.
That makes sense to me, but as the lower gear goes in on downshifts the engine revs must rise instantly, which is not possible surely because of the engine inertia? - this would mean the back wheel would ‘skip’ unless the slipper clutch slips???
The engine blips to match engine RPM to gearbox RPM.... So it's perfectly matched.
That’s the bit I don’t get because the engine and gearbox are only ‘disconnected’ be for a minuscule period of time as the dogs slide - the revs surely cannot rise sufficiently in that period of time? Do any bikes have an auto-blipper and no slipper clutch?
Ok, you could be right because my Triumph 675R had no slipper clutch... but the quickshifter only went UP the box not down.
So the Auto-blipper quickshifters have only been mainstream for the past few years... as slipper clutches have been as well.
Never linked the two before... maybe thats the reason.
I am happy to be corrected
I’ve just spat out my tea.......
And the answer is?
I am going to stick my neck out here and say that for downshifts an auto blipper only works if you also have a slipper clutch
I am happy to be corrected if there is a bike on the market with an auto-blipper for downshifts and no slipper clutch, but I cannot see how the revs could rise fast enough
