Steny365
Hi folks looking for advice , have a 08 GS ,when I pull my front brake lever I can hear a hissing sound of air wondering if this is normal ,I don't have servo brakes , I'm thinking maybe my master cylinder is on its way out , cause sometime not all the brake lever would go in a far bit but Harding up when I pump , brakes are bleed but as I have said I'm hearing a hiss/air noise when I pump the lever and seems to come from cylinder,no leaks anywhere to be found ,
Anyone have this issue before that lead to it been the master cylinder or I should noise normal and maybe I still have air in system,
