I have that double USB also I ran the cable to the back of the hella plug and soldered it on there I believe you can get an adapter if you don't want to cut and solder the wires. I mounted the USB on the left hand side of the fairing mount just above the oil cooler lines. Then I ran an iPhone charging cable up to the screen mount with a quadlock mounted on the cross brace of the screen. I'm happy enough with it.
That would look half decent if you sprayed the bracket black.
Be careful if you wire a USB socket direct to the battery. They pull a bit of current even when not in use.
Slave it off the aux socket or the GPS plug.
They all do. Some only a tiny amount - depending on the quality. Obviously if it has an led display, it'll be more.Do all USN sockets draw a little power or just the ones with the LED Voltage indicators etc?
Not an issue if you're using the bike regularly, but if it's laid up for a few months, it's enough to make a difference.
10mA current is a couple of Amp/hours per month.
Wired to existing bmw plug so stays on for ten seconds after ignition turned off the goes out, and was just about to paint it when I took first picture.
I bought a double USB charger as in image and looking for some advice on where to mount it based on experience from members here.
Thanks in advance.
S.
Not sure if you've solved it but I recently bought the same USB port as you and pondered where best to put mine.
I eventually unscrewed the sticky pad mount and removed the screw/nut. Expanded the hole and refitted the plastic clamp to the windscreen frame bolt (similar to toy40) and routed the cable under the tank to the left side DIN plug. Cut off the battery terminals and fuse holder the charger came with and wired it directly to a male DIN plug which now plugs directly into the bike and is only activated with the ignition.
The USB port can be removed from the holder easily should I need to access the headlight bulb.
Hopefully the URL below works and you can see pictures of the installation which seems to work fine and is not in the way of anything.
https://1drv.ms/f/s!AsG_JXsk0BzCkTDeCxiOFEJsK_XU
