Hi Folks,
I am doing a bit of maintenance on my 2014 R1200RT LC shaft drive. There was a split at the bottom of the 3rd segment of bellows at the gearbox end and I decided to remove the swing arm drive shaft to replace it. The shaft came off the gearbox output shaft during removal but seems a bugger to slide back on?. Is there an index spline on this shaft I know there is one my 1150 but the 1200 looks pretty uniform??. Also there seems to be an indent for a snap ring but there is none? I assume there should be? All input gratefully received.
Thanks.
Thanks.
