rivercatch
I would be interested in comments or advice on the following situation.
TL;DR: Bike recovered to dealer. Dealer finds problem in cam chain tensioner. Not covered by warranty. Also requires new rear brake disc because too thin after only 8000 miles. What to do?
I have April 2013 1200GS TE model. Only 8000 miles (very low mileage because I had to start working overseas shortly after purchase). It has been dealer serviced annually and I have maintained BMW Insured Warranty. It was last used regularly (most days) on a short commute (~8 miles each way) between July 2018 and March 2019 with no issues. Had a trip and came back in April. Bike always left under cover, in driveway, with CTek battery tender. Had one run with no problem. Came back late May and bike wouldn’t start - no crank. Got a new AGM battery. Now would crank but would not start (like cranking for a minute or so). Had to go to work and returned in early June to the same problem - cranked but would not start.
I called the roadside assistance as part of the warranty. They sent an engineer to assess the problem. When he tried, the bike started first time, which was embarrassing! But after starting there was clearly a wrong noise from the engine. He decided this was serious and recovered to dealer (in Battersea) for investigation.
Service manager calls and initially asks for 4 hours labour authorisation for investigation, payable under warranty if warranty claim. I ask for annual service to be done as well. They will check the whole bike.
He calls back this morning. The wrong noise was due to a stuck hydraulic tensioner (not sure I got this right). They will need to replace this (about £185, but they have only used 1.5 hours so far) and it is not covered under the warranty. The warranty is ‘named components’ and this is not a named component. Additionally the rear disk brake thickness is below tolerance and should be replaced. The rear disk pads are 50% worn. They recommend immediate replacement but it could wait for pad replacement.
So I check the warranty (page 17 for those interested) and it gives:
Engine
All internally lubricated components, including the following:
Failure of the following parts: [stuff], timing gears and chain, [stuff].
As I see it the tensioner must be part of the chain as the chain cannot work without it. But is it a wearable or consumable part?
Also the brake disk - is there a known problem? Given low mileage and that I’m riding on the original pads which are only 50% worn, this doesn’t seem reasonable. I don’t really use rear brake alone, and I don’t think my toes are resting on the brake either. I’m inclined to leave this until the pads need a change - at my rate it could be a couple of years.
Engine
