Safety Alert rear brake reservoir.
Halfa1200
Bedfordshire, England
No fluid in rear reservoir but brake still working. On checking the rubber pipe from the rear reservoir to the master cylinder I found that the middle plastic clip holding the rubber pipe had split the pipe due to the clip having an edge on it. Will be replacing the pipe and also dumping the clips and using cable ties instead.
Halfa 1200
