Page 2 of 2 FirstFirst 12
Results 17 to 28 of 28
Thread: Oil Carry Bottles
  1. #17
    Join Date
    Sep 2007
    London & Cheshire, England
    Posts
    162
    MMD Bottle Holster Black for motorcycle and luggage https://www.amazon.co.uk/dp/B076ZKB5..._XfZeDbJGRWTHQ
    This could be the answer. Just need to find somewhere on the bike to strap them
  2. #18
    Join Date
    Sep 2007
    Posts
    162
    Exactly what I did last weekend for a 4 day trip to Vianden. I used it all & it leaked in between top ups. I’m worried if I use something less viscous, over 3 weeks in 35/40 deg I’ll be effectively changing the oil from 20/50.
    Quote Originally Posted by Timolgra View Post
    The amount you're likely to use for topping up won't make any difference to keeping the engine quieter by using 20/50 but since that doesn't answer your question and you're insistent, why don't you just buy a 1L bottle of 20/50 with a built in spout?
  3. #19
    Quote Originally Posted by Spangle View Post
    Righty tighty, lefty loosey
    Just put it in a alloy fuel bottle and be done with it then
    KEA
  4. #20
    Join Date
    Sep 2007
    Posts
    162
    there only seems to be half a turn on the cap of them there 1l bottles & if you righty tighty too much it breaks the thread
  5. #21
    Well it's a feckin suprise the rest of the world who carry petrol for their stoves haven't all been incinerated
    C'mon man, you're a 1150adv owner, don't let the side down.
    Here, I'll give you a clue of what I do for a month long hard offroad ride.
    Plastic oil bottle with some insulation tape to secure the cap after it's been opened, bottle stuffed inside a piece of old inner tube. Sorted.
    KEA
  6. #22
    Join Date
    Jan 2014
    Lancashire
    Posts
    335
    Quote Originally Posted by jonnie comet View Post
    Where are you going, that is so far away from civilisation, that you can't just buy oil when you need it?
    I have never ever needed to carry oil.
    i like to take 200ml in 2 x 100ml clear plastic bottles - the type you buy to take liquids on airplanes. The bottle tops are taped up and then they are in little sealed sandwich bags to catch any leaks - I keep them under the seat on my GSA.
    Ok, its only 200ml - but if the bike did run low (and experience tells me it likely wont, it doesn't seem to use much) then 100 or 200ml will be enough to get rid of the "low oil" warnings until I can check the level and buy some more at a garage if needs be.
    Nothing worse than a warning light at the top of an alpine pass to make you worry al the way down the other side!
  7. #23
    Join Date
    Sep 2007
    Posts
    162
    I have no fear of incineration, only snakes & large ladies
  8. #24
    Separately or together? If it's together you must have a good story to tell.
    KEA
  9. #25
    Join Date
    Sep 2007
    Posts
    162
    Any particular type of old inner tube?
  10. #26
    Now you really are taking the piss
    KEA
  11. #27
    Join Date
    Sep 2007
    Posts
    162
    I used to have a large female following but I managed to shake her off after a couple of bends...
  12. #28
    Senior Member
    Join Date
    Apr 2005
    Fareham, Hampshire
    Posts
    13,229
    Unless the 'large' lady is Salma Hayek. Have you seen the snake dance in "From Dusk 'Till Dawn" ??
Posting Permissions
  • You may not post replies
  • You may not edit your posts
UKGSer is....
"I have always known this community is full good people even if most of you cover it up with piss n vinegar" Chad 2018
"Its about being a grown up hooligan - and if that means a dark visor, remus open pipe and a bit of speeding out of town then all well and good" Kaister 2005
