Battery is in good nick.
Replaced the white 'switch' piece at the bottom of the key barrel.... checked the key positions and it works correctly, so the switch was in the right position before putting it in the key barrel and doing up the grub screw (I didn't lose the original, even though it is TINY!)
Coupled up the orange block and tried it - nothing.
Took the key switch end back out and tried it using a screwdriver - still nothing.
Is it possible that a brand new switch unit can be duff? If not, where next to look please? Turning the key does nothing, no dash lights, no fuel pump whirr, but the clock is still going, which doesn't tell me how many sparks are in the box, but it does indicate that there are some and as it got a full charge from a proper charger, I know it is well stocked with moveable electrons.
Going bald from scratching my head here!
