Steny365
Hi all , I'm looking for advice , I noticed my bike seems very light on motorway speeds I have adjusted the preload up on rear shock and have front set at two , it feels like it's extremely light if you get me , I changed out headstock clamp bearing etc , I'm wondering if someone could advise the telelever ball joint can these cause a light feeling issue , rubber part looks perfect , when I have it up on stand there doesn't seem to be any play in ball joint , but with wheel of the ground turning handle bars left to right is extremely light I know it cause wheel of the ground but I'm wondering are these joints new are on the stiff side and maybe mine is worn internally and is on the loose side would that be possible , other thing I noticed is a clunk noise from front when I have brakes applied and pushing down I have found that this clunk noise is the discs moving on the rivets there's some play in them ,anything I can look for I believe the bike should more stable than that
