Hex Ezcan + Denali D2 Lights. Plug & Play?
Bonzo
Warwick Hunt
..or is there any cutting & splicing required?
Asking as the Ezcan is £80 cheaper than Denali's Smartcan at the moment.
Thanks for that Smogbob.
So its not the £150 jobbie from Nippy Normans I need, but the Gen 2 at £189. Still £40 cheaper than the Smartcan though :beerjug:
Exactly Nippy has the older version at the moment, not the same connectors, the new GEN2 has same connectors as Denali, simply because they are the same company, I see no difference between new GEN2 and Cansmart, except that the cansmart has extra cables for the lights and horn
https://denalielectronics.com/collections/accessory-mangement/products/dnl-whs-11600
Aah, actually didn't realise Id need a Y splitter cable.
(Your link was for a £19 light cable - the Y splitter cable is £30)
**EDIT** Scrap that. Just read what they were.
Thanks again :beerjug:
The light cable is all you need 19 quid as the Ezcan or the cansmart sits under the rear seat, and you need the long light cable to attach the 2 together, look at my pics below.
