Hi folks, I recently Mot'd my twin cam R1200RT and the Mot tester commented on play on the final drive and suggested I keep an eye on it.
I checked further. The final drive appears sound. There is no play there. However I have side movement on the swingarm, between the fixed bearing stud on the right and the adjustable on the left. About 1.3mm.
Took the swingarm off and cleaned and re greased the bearings and they appear ok. The bearing studs appear ok, though I haven't got new ones to compare side by side.
Having refitted and retorqued everything there is still this gap. Adjusting the left bearing stud doesn't seem to change anything.
Is this sideways movement/ gap normal or acceptable? Am I likely to develop any further issues? Otherwise the bike runs ok with no handling problems!
Your thoughts are appreciated,
with thanks,
Mario.
with thanks,
Mario.
