Fitted today to my 2017 F700GS..
What a joy to fit..
Plug & play wiring, including a trigger wire off the sidelight
( but changed it as the headlight wiring is sealed, so took it off a other live feed )
Had to change the spotlight mounting bolts to slightly longer as the 700GS's front plastics are narrower & would of rubbed, but only took 10 minutes.
( you could bend the brackets inward, but I'm as week as a kitten so changed bolts )
The switch is aluminated that changes colour for on/off.
Now I've had all sorts of non OEM parts fitted to my array if bikes over my 43 yrs of biking.
Including 6 F series twins & I can honestly say the fit, finnish, quality & ease of installation is second to none.
Highly recommended & these would fit a 650GS twin as well..
Very powerful to boot..
Absolutely no skills or specialist tools needed , just a set of Torx & Allen keys
I also have Cyclops H7 LED headlight bulbs, expensive yes but well worth the cost.
As night turns to day when out at night...
Denali Sound Bomb Mini 113dB Horn highly recommended as well
