Auto voice prompts Garmin Nav 6
Mark H
Formerly known as Easyrider5258 (Mark)
Remotely in East Anglia
Garmin nav 6 I only seem to get route prompts manually by in navigation screen on R1250RT you move wizzy wheel to speak and push to right for direction?
Thought it used do this automaticly, can't see how to restore
Sent from a reststop near Innsbruck:D
You can try a couple of things:-
1) Turn unit completely off and then on again and replace in cradle.
2) With the device in the cradle, use the whizzy wheel to mute and then un-mute the device. This trick would work with the Nav 5.
Good luck,
John
Mine work as you said - use the thumb wheel to navigate to sat nav page, then "speak", then push right to get the instruction. You can use this to repeat instructions, or for entertainment on a long ride!
BUT it also does it automatically as you're going along so you don;t really need the "speak" function. Must be in the settings somewhere.
id remove the battery for 10 secs then reinsert and reboot, This would be better than just turning off and back on
Thanks chaps sorted now, for info go to main screen / volume/option to enable/disable auto voice prompts, sorted��
