They Couldn't replicate the fault but fit a new fuel cap as its a known fault apparently! So I hope thats my glitches over and done with .
better than getting fobbed off
Don't you need the fobb to open the cap
As long as fob is good.
I had this happen in France bought a tin of WD40 then eventually found the problem.
What it turned out to be ......I was faffing about with a pay pump by the time I'd sorted it the petrol cap had timed out after 2 mins so turning ignition on didn't do anything as it wont open with it on but turn it off and open within 2 minutes it'll be fine
It's keyless ? I did 15,000 miles on 2017 Exclusive with keyless not a single issue.Just as well I wasn't far from home,that trip to the Alps next year is definitely off I'm off in the car
Had the same problem yesterday and Williams Manchester spoke to me with a fix. The problem was low fuel on a really hot day and the gas pressure in the tank was preventing the cap from opening. The fix is to press the front of the cap when trying to open the latch and it works!
Always done that from the day I got the bike but mine still failed and was replaced under warranty, so dealer obviously agreed there was a fault.
Mine was replaced under warranty 4 months ago. They fail
On mine it will not open no matter what, until i press the ignition button and turn the bike OFF
If i just stop the engine and the dash is lit up, it wont open.
2 seconds after pressing the power off.... opens every time.
