Spline grease: as I understand it, the grease is effectively just a carrier for the molybdenum it contains. It's the residual molybdenum that's important. If it's sliding freely, all is good.
hello folks
I posted a few messages about a knocking feeling coming up though the seat it turns out that the shock is done hurst motorad are gonna apply for a goodwill fix from bmw but they said it could be repaired for 450 quid if bmw refuse the bike is a September 2017 bmw 1200 gs lc adv with 25k on it and no off road use ever I honestly think that's a bit early for giving problems like that plus the final drive was replaced about six weeks ago under good will at a cost of 2500 pound which I had to pay 450 pound a new shock is 1800 quid ,I have this machine from new didn't realise a bike cost 16k could give so many expensive problems ……….anyone got any advice would be much appreciated
many thanks Pat
Rear paralever to bevel box bearings , needle roller lasts about 2 years or so
Hi Neil
In relation to this, I need to pick your brains...
My 2016 GSA with 26k miles drives fine with no discernible play in the FD. However, what I notice is that when riding over roughly surfaced roads, especially on a closed throttle, I can feel every ripple of the road up through the bike / footpegs etc. On a positive throttle it's not really an issue.
I'm talking about otherwise smooth roads with a poor surface finish. Do you reckon that the bearings you mention could be the cause fo this ?
My previous TC GSA never gave a sensation like that.
Fergus
Just take the control arm off (one bolt) and wheel.. and see if you can find any play in the bearings. It's quite obvious when they have gone....
Where the fuck is Tarka when you need him?
hello folks
many thanks Pat
I did that. bearings seem fine.
Must be a combination of the tyres, metal footpegs, shock absorber etc. Bike is a 2016 GSA basic (no ESA)
Shocks front and rear in perfect condition.
It's a strange one.
Anyone else get that rough feeling coming from the back end over poorly surfaced roads, especially on a trailing throttle ?
It's a strange one.
I have a long commute on my 2018 1200GSA and on anything other than a glass smooth road surface , I get exactly those symptoms you describe.
I currently have Pirelli Scorpion Trail IIs fitted which have quite stiff sidewalls. Am changing to Metzler Roadtec 01s in a couple of weeks so if the feeling improves I'll let you know.
