On the newer bikes they did away with the drain hole and it now drains through a pipe under the bike - no change really, but what you don’t see doesn’t hurt you
Until it gets on your rear tyre or your engine seizes
Is there a warning light that tells you the engine coolant is leaking on to the rear tyre ?
The amount that comes out of that hole ain’t going to cause a problem to the rear tyre.
