K1300s 2011, 56k miles.
Hi, I need to remove the driveshaft on my K1300s. I have removed (lowered) the final drive and the driveshaft slides out from the swing arm for a couple of inches, but then something is stopping it sliding completely out..... do I just give it a good pull?....any ideas?
Also, there is slight 'notchiness' on the driveshaft rear uj when I swivel the knuckle through its axis's..... is a slight amount of notchiness acceptable?
Finally, when I rotate the final drive shaft by hand, which is now disconnected from the driveshaft, it makes a slightly rough sound, a bit like a 'scraping' kind of a sound, there are no oil leaks and there is no play in it. It has had oil changes during services.
